Diesel Forum - TheDieselStop.com - View Single Post - Dieselsite Coolant filter installed - 6.0 Van
Old 11-09-2009, 09:55 PM   #11 (permalink)
MikeL46
MikeL46's Avatar
My Photos: (14)
I don't seem to have a metal ring or sleeve on/in the heater hose. I can compress it with my fingers. I'm going to see if I can compress the hose (wiht tools) to prevent coolant loss. This would be alot easier if the engine wasn't in there, or at least the alternator.
I haven't yet decided where to mount the filter. It could go behind the bumper, or as you did, mounted to the frame. That will be the first step. And I like your idea of routing the hosed before cutting into the heater hose.
I guess I have to fix my wife's VW Vanagon first, then onto the real van!
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline   Reply With Quote
