cool --- i have to work tommorow ill get on it wens morning, im getting from what you say to bring up my high idle first to 3100 in neutral, then adj mixture 1/4 turn and test, i should look for 1200 degrees on a good load [as in a hill i dont have to downshift for] would that be correct ?
again thank you for your time hopefully i wont have to go into the timing
once more the diagram does not show the aneroid tube i have, the box still just lifts off?
i cant wait to give it a try
