Diesel Forum - TheDieselStop.com - View Single Post - Just purchased the coolant filter
Old 11-10-2009, 12:10 PM   #13 (permalink)
MikeL46
MikeL46's Avatar
My Photos: (14)
Originally Posted by Joe Shemoe View Post
You will be amazed with the improvement you'll get with this
coolant filter installed. Damn, it cant get any better, I regret not putting in one early on
Say it ain't so Joe!
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline   Reply With Quote
