Diesel Forum - TheDieselStop.com - View Single Post - Headlights
Thread: Headlights
Old 11-10-2009, 12:38 PM   #8 (permalink)
FJK1
I just did this 2 days ago on my 99. You don't have to remove the batterys or the grill filler. Just remove the headlights. The "trick" is removing the silver clips. I saw all the tips listed on this forum, but they were ineffective. I used a flat blade screw driver that I heated the tip with a torch & bent it into a "U". I use this tool to remove heater hoses. I used this tool to remove the headlight clips. The clips are spring clips, so they need an impact load to pop them loose. So, I got under the clip with my u tip screwdriver and gave it a sharp yank. The clips pop out without damage & can be reused.
FJK1 is offline   Reply With Quote
