Diesel Forum - TheDieselStop.com - View Single Post - Engine Surging, Poor Fuel Economy
Old 11-10-2009, 01:52 PM   #12 (permalink)
4ceFed
4ceFed's Avatar
Where is your ICP sensor, on the valve cover or under the turbo? Also that P0611 code means that your FICM is probably bad, if you have access to a scanner you can monitor FICM M_PWR and it should never drop below 45 volts. I have seen engines that run weird due to low injector voltages.
4ceFed is offline   Reply With Quote
