Diesel Forum - TheDieselStop.com - View Single Post - Ford recall 09S09 Safety.
Old 11-10-2009, 08:25 PM   #10 (permalink)
boomboom
boomboom's Avatar
My understanding of this recall is if the fuse blows out in the future they will still replace the sensor as a recall issue at no charge. It's just cost effective this way because 99% of the switchs won't fail anyway .The fuse is just to prevent a possible fire if the switch fails.
boomboom is offline   Reply With Quote
