Diesel Forum - TheDieselStop.com - View Single Post - burning oil
Thread: burning oil
Old 11-11-2009, 10:38 AM   #3 (permalink)
cdnsarguy
cdnsarguy's Avatar
My Photos: (109)
Are you filling it back up to the line on the dipstick.......
Post from a pro......
DieselDon
Oil consumption, and the proper checking of the oil levels in Ford diesels comes up periodically. Ford dipsticks are calibrated for hot oil. The 10 quarts in the IDI engines expand about 1/2 to 3/4 of a quart as the oil heats up, and contracts the same amout after cooling. If you check the oil first thing in the morning ( which I grew up doing ) the engines will all indicate oils level below full, but when checked hot, will ( after a 10 minute drain time ) the oil level is usually at full. If you are checking the oil cold, and keeping the level at full, you are actually over filling the engine which will burn of the extra rapidly.
Suggestion: Check oil hot after 10 minute drain time.
Don't add until level reaches add line ( 2 quarts ).
In my days at Ford this often cured, or at least improved, the apparent oil consumption complaints.
Proud Canadian BOOB man too!!
cdnsarguy is offline   Reply With Quote
