Diesel Forum - TheDieselStop.com - View Single Post - burning oil
Thread: burning oil
Old 11-11-2009, 11:05 AM   #4 (permalink)
Joe Mc
Joe Mc's Avatar
My Photos: (39)
From the Ford TSB on oil burning:
OIL DIPSTICK (6.9L) - ENGINE OIL LEVEL CHECKING PROCEDURE
LIGHT TRUCK 1983-86 E AND F SERIES
In order to measure engine oil levels consistently and accurately, it is useful to employ the following recommendations:
 Park vehicle on level surface. Low oil level readings will be obtained if the vehicle is sloped away from the dipstick.
 Have engine at normal operating temperature as oil expands at the rate of one percent per 25~F (14~C) change and the dipstick is calibrated to the engine at normal operating temperature. In addition, allow at least a fifteen (15) minute engine shutdown period to assure that oil contained in the upper parts of the engine has returned to the oil pan.
 Have dipstick loop directed inboard as this eases installation and minimizes wiping action on oil level gauge.
 Read oil level on both sides of gauge and use highest level (reading) for the actual engine oil level.
Correct oil dipstick calibration can be verified by draining the engine oil and filling the engine oil pan with nine (9) quarts (8.5 liters) of oil. When the oil dipstick is properly seated, correct dipstick calibration is indicated if the oil level is within 1/16 inch of the "Full" mark.
NOTE: The area between the "Add" and "Full" marks represents two (2) quarts. As long as the oil level is between the "Add" and "Full" marks, no oil should be added. When the oil level does reach the "Add" mark, only one quart of oil should be added. If the oil level exceeds the "Full" mark, oil consumption could result.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
Triple A-pillar pod: Isspro EV voltage and oil-pressure gauges.
Road-Watch System (Air and road-surface temperature gauge).
Chicken Lights Gone.
Joe Mc is offline   Reply With Quote
