Diesel Forum - TheDieselStop.com - View Single Post - 6.0 PSD antifreeze leak
Old 11-11-2009, 07:50 PM   #3 (permalink)
teamroper60
teamroper60's Avatar
Originally Posted by red.26 View Post
ok guys im new to the diesel engine so any help would be nice. i have an 05 f-250 that leaks antifreeze. it drips from the back of the engine. so i did some research on this forum and found that the egr cooler hose is a common leak on this motor. if that aint what it is what else could it be? but ive got another question. my reservior cap was leaking and i replaced it but it still leaks??? so any help would be nice! thanks.
If it were not for the last sentence, I would say the EGR cooler hose was the most likely problem and it still may be the reason you have coolant at the back of the engine but maybe not...
"Leaking" from the degas bottle (overflow bottle) is an indication of too much pressure in the cooling system. Without proper diagnosis, it is a shot in the dark as to the cause but the usual suspects are the EGR cooler, oil cooler, viscous fan clutch and headgaskets. If you do a search for "puking" in this forum, you will find enough reading material to educate yourself on each of these possible causes..
A bad EGR cooler could cause a leak, so could bad headgaskets.. So, you really need to get this properly diagnosed.....
pics
#43
SLAPS President and Webmaster
teamroper60 is offline   Reply With Quote
