Diesel Forum - TheDieselStop.com - View Single Post - Remote starter problems
Old 11-12-2009, 09:29 AM   #12 (permalink)
bondsman
Originally Posted by riddick01 View Post
it sounds to me like you have the edge wired up to a dead fuse when u use the remote start. ive got a clifford remote start system on my truck and if i remote start my truck the only thing that will come on is the radio and the ac. for some reason nothing else will come on (headlights included)
But when you put the key in and turn it to the run position, everything works. His edge is not firing up. Maybe the edge has to be powered up before the truck starts (in accessory) otherwise it won't powerup.
Here is what you do... remote start your truck and see what all works. find a fuse to something that is working and tap your edge power into that fuse. you should be golden then..
2005 F250 LARIAT CC 4X4 6.0L PARROT CK3200 bluetooth car kit, Shaker 500 system, nice set of train horns, twin viair compressors and 5gal tank, 5" MBRP turbo back, AFE stage II intake, SCT tuner.
1996 F350 AT, IDM and switched ICP mod
1995 F250 SC AT, IDM and switched ICP mod, 6" susp 2" body lifts.
1994.5 F250 SC 5spd 4x4 IDM and ICP mod
bondsman is offline   Reply With Quote
