Diesel Forum - TheDieselStop.com - View Single Post - intercooler install on way
Old 11-12-2009, 07:48 PM   #23 (permalink)
rpm1
It's not a blow off valve, it's the wastegate. But the main reason the van turbos are desirable is that is has a 1.15 turbine housing vs. the trucks .84. Lose a little off the bottom, but more than make up for it on the top end.
When you get this intercooler done, with all else being the same, you will lose boost, but make more power. The cooled air takes up a lot less space, even though there is more of it.
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, Swamps Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 300cc hybrids, racerx trans and tc, water injection
rpm1 is offline   Reply With Quote
