Diesel Forum - TheDieselStop.com - View Single Post - Intermittent Cruise Control Function
Old 11-13-2009, 11:20 AM   #4 (permalink)
BeatMarti
BeatMarti's Avatar
Originally Posted by 250_SD_Beast View Post
Took my truck in yesterday - turned out to be the brake pressure switch. Cruise thought that the brakes were applied so it would not engage. Took a few hours total to troubleshoot and fix. Seems to work as it should now.
I had the same problem. Replaced the pressure switch and it worked for a few hours, then it started again. It turned out that the wire harness connecting the pressure switch was "stressed" to the point that one of the wires got torn inside the insulation and stopped making contact. The pressure switch circuit (when open) reports "pressure on", hence, the cruise control will not come on.
I fixed the harness and all's well since.
BeatMarti is offline   Reply With Quote
