The GVWR apllies to whatever weight you have on the truck itself. So, whether it's a camper or trailer you are hauling, you can only have as much weight on the truck as what the truck is rated for. If you know how much the truck weighs, you then add weight of gear, fuel and persons in it, then you subtract that from the GVWR, that will give you the amount remaining that you can legally add to the truck. Also, that weight could be the weight of a camper, pin weight on a 5-er or hitch weight on a tag-along trailer. Hope this helps.
05 F-350 Crewcab 4x4, 6.0, Auto, Dually, My new Tow Rig
95 F-350 Crewcab 4x4, 7.3, Auto, Awesome Tow Rig...Sold on May 17/09 (went to a good home)
80 F-250 4X4, 429, 4 Speed, Lifted, Solid Axles, Boggers, 450,000km and going strong...Gonna Go
90 Bronco, Work in Progress
