Originally Posted by 69cj
80,000 in my manual
Your engine emissions warranty is 100k. The verbiage below is from the 2005 warranty manual. Our trucks are over 8500 GVWR.
EMISSIONS DEFECT WARRANTY COVERAGE
During the warranty coverage period, Ford Motor Company warrants that:
• your vehicle or engine is designed, built, and equipped to meet - at the time it is sold - the emissions regulations of the U.S. Environmental Protection Agency (EPA).
• your vehicle or engine is free from defects in factory-supplied materials or workmanship that could prevent it from conforming with applicable EPA regulations.
• you will not be charged for diagnosis, repair, replacement, or adjustment of defective emissions-related parts listed under
What is Covered?
on pages 13-15.
The warranty coverage period for:
• Passenger cars, light duty trucks (vehicles with a GVWR of 8,500 pounds or less, or over 8,500 pounds if certified to light duty emission standards)
— 8 years or 80,000 miles (whichever occurs first) for catalytic converter, powertrain control module, onboard emissions diagnostic device, natural gas vehicle (NGV) module (Bi-fuel/CNG), electronic emission control unit, and transmission control module;
— 3 years or 36,000 miles (whichever occurs first) for all other covered parts.
• Heavy duty vehicles (vehicles with a gross vehicle weight over 8,500
pounds)
— 5 years or 100,000 miles (whichever occurs first) for covered diesel engine parts;
— 5 years or 50,000 miles (whichever occurs first) for all other covered
parts.
EMISSIONS PERFORMANCE WARRANTY COVERAGE
Under Emissions Performance Warranty Coverage, Ford Motor Company will repair, replace, or adjust - with no charge for labor, diagnosis, or parts - any emissions control device or system, if you meet all of the following conditions:
• You have maintained and operated your vehicle according to the instructions on proper care in the Owner Guide, the Scheduled Maintenance Guide and this booklet.
• Your vehicle fails to conform, during the warranty coverage period, to the applicable national EPA standards, as determined by an EPA approved inspection and maintenance program.
WHAT IS COVERED?
These parts are covered by both the Emissions Defect Warranty and the Emissions Performance Warranty.
List of Parts Covered by Emissions Warranties For Cars, Light Duty Trucks and Heavy Duty Vehicles
• Air Flow Sensor
• Air/Fuel Feedback Control System and Sensors
• Air Induction System
• Altitude Compensation System
• Catalytic Converter
• Cold Start Enrichment System
• Cold Start Fuel Injector (1)
• Controls for Deceleration
• Electronic Ignition System
• Exhaust Pipe (Manifold to Catalyst)
• Electronic Emissions Control Unit (ECU)
• Electronic Engine Control Sensors and Switches
• Evaporative Emission Control System
• Exhaust Gas Recirculation (EGR) System
• Exhaust Heat Control Valve
• Exhaust Manifold
• Fuel Filler Cap and Neck Restrictor
• Fuel Injection System
• Fuel Injector Supply Manifold
• Fuel Sensor (1)
• Fuel Tank (non diesel only)
• Fuel Tank Pressure Control Valve (1)
• Idle Air Bypass Valve
• Ignition Coil and/or Control Module
• Intake Manifold
• Intercooler Assembly - Engine Charger
• Malfunction Indicator Lamp (MIL)/On-Board Diagnostic (OBD) System
• PCV System and Oil Filler Cap
• Powertrain Control Module
• Secondary Air Injection System
• Spark Control Components
• Spark Plugs and Ignition Wires
• Synchronizer Assembly
• Throttle Body Assembly (MFI)
• Transmission Control Module (TCM)
• Turbocharger Assembly
• NGV module (Bi-fuel/CNG)
List of Parts Covered for 5 Years or 100,000 Miles (whichever occurs first) by Emissions Warranties for Diesel Engines
• Air Flow Sensor
• Air Fuel Feedback Control System and Sensors
• Exhaust Manifold
• Powertrain Control Module (PCM)
Important Information About List of Parts
Also covered by the two emissions warranties are all emissions-related bulbs, hoses, clamps, brackets, tubes, gaskets, seals, belts, connectors, non diesel fuel lines, and wiring harnesses that are used with components on the list of parts, above.
Concerning parts that should be replaced on a certain maintenance schedule: these parts remain under warranty until : (a) the first replacement time that is specified in your Owner Guide and the Scheduled Maintenance Guide; or (b) the time or mileage limits of the Federal Defect and Performance Warranties (whichever occurs first). Your Ford Motor Company dealer maintains a complete list of parts covered by emissions warranties. For more details about the specific parts covered by the Emissions Defect Warranty, contact your dealer.
WHAT IS NOT COVERED?
Ford Motor Company may deny you warranty coverage if your vehicle or
a part has failed because of abuse, neglect, improper maintenance, unapproved modifications, or any items included in What Is Not Covered?, pages 7-9.
