You need to contact Ford customer Service with this. If they do not help, contact the EPA. The EGR valve IS INTENDED TO BE COVERED by the EPA (as long as you operated the vehicle as intended AND you did not modify it).
Also, the FICM is covered for 100k miles - it is CLEARLY part of the Fuel Injection System.
Ford Motor Company
Customer Relationship Center
P.O. Box 6248
Dearborn, MI 481211-800-392-3673
(FORD)(TDD for the hearing impaired:
1-800-232-5952)
Owner Support - Ford
Manager, Certification and Compliance Division
(6405J)
Warranty Claims
Environmental Protection Agency
Ariel Rios building
1200 Pennsylvania Avenue, N.W.Washington, D.C. 20460
Mark
