Diesel Forum - TheDieselStop.com - View Single Post - 99 PSD with miss(es) and intermitten
Old 11-13-2009, 11:23 PM   #5 (permalink)
MochaMan
Originally Posted by 4x4Nut View Post
This one won't restart fine if it's missing. It doesn't come and go that bad. The clips are for the under valve cover wire harness. Where the harness plugs into the valve cover gasket, the catch to lock the connector in place can weaken and come loose. When this does it will break circuit to the injector(s). There are clips to install in order to keep the connections locked in place.
I'm going to work on the truck more this week to try to figure it out. Any suggestions are still welcome though.
I have the exact same problem. I have a 99 F350 dually 7.3 4x4 with 80,000 miles. I have installed the clips.......no change. I would love to know what you find out. I own a 96 F350 7.3 2wd with 150,000 and the difference is night and day. You would never know they are the same motors.
MochaMan is offline   Reply With Quote
