Diesel Forum - TheDieselStop.com - View Single Post - New Starter.. started, ran, died...
Old 11-14-2009, 01:37 AM   #7 (permalink)
speeddemon31176
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
Yes it is different as when clearing the codes, all you are doing is clearing saved codes that are stored in memory. When you completely disconnect power from the pcm it clears all previously learned parameters of the various sensor and will relearn everything upon starting the truck and running it. Just try it. What is the harm in a possible free fix?
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
speeddemon31176 is offline   Reply With Quote
