Diesel Forum - TheDieselStop.com - View Single Post - Dieselsite Coolant filter installed - 6.0 Van
Old 11-14-2009, 07:52 PM   #12 (permalink)
MikeL46
MikeL46's Avatar
My Photos: (14)
I finished the coolant filter installation today!. The hardest parts were deciding where to mount the filter and how to route the hoses. I have an aftermarket front bumper and mounted the coolant filter in the bumper. If I had a stock bumper I don't know how I could have mounted it.
I also needed about 6' extra 3/8" heater hose. It was hard to find a good parts house that carried it.
When I cut the heater connection, only about 1-2 teaspoons of coolant came out. Maybe because the engine was dead cold, not having been started for several days.
I was able to pull an AC line forward and far enough out of the way to be able to get at the heater line.
Now I need to drive it enough to see some results.
Thanks to ridintall for doing his installation and giving me the courage to try mine.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is online now   Reply With Quote
