Diesel Forum - TheDieselStop.com - View Single Post - Can't find a rattle
Old 11-14-2009, 09:05 PM   #18 (permalink)
dlblazer
dlblazer's Avatar
Its been a good weekend. I finished the gauge install, and then went for round five to try to find the source of the rattle.
While under there I found a black widow spider (or she found me) as she came after me. I had seen webs, but it was a bigger spider than I expected.
After killing her, I went to find the rattle.
I finally found it. It was the brackets holding the air bags to the rear springs. Why I didn't find the source earlier was because the bolts were tight. What they did was install the air bags over the stock overload springs. Then they inserted a bracket under the overload and then secured it with brackets under the main leafs. The brackets between the main leafs and the overloads could move just enough to rattle.
Well I feel better and the truck is nice and quiet.
Thanks for all the help.
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter (no more), Superchips 1705 tuner, Reese Titan, AIS, IPT pre-pump filter kit, in-tank mods, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
dlblazer is offline   Reply With Quote
