possible to do head studs only but IMPOSSIBLE to do head gaskets without removing cab on 6.4,just finished ones on this one,way more labour than 6.0,way more money and time and parts as all high pressure lines and egr bolts and gaskets must be replaced,special torque sequences also on all egr coolers,brackets,pipes and band clamps,i useta ***** about the 6.0 head gaskets but these ones are out of this world.......first 2 cab bolt blind nuts broke and had to be welded ,what a start......hope this is the only one i have to do and all the rest hold together!!!!!!!!!!!!!!!!!p/s early build date job 1 trucks have 6.0 gaskets and not updated ones....enjoy
1996 F350 CREW CAB,37"tires,2003 hpop,160CC injectors,electric fuel system.malery pressure reg.6.0 intercooler,sd bd turbo,sd 3 in intakes ,tw 4 pos. chip,gauges,tcc disconect,mod.e4od,rear detroit,20,000remote cooler,baja fiberglass body panels,stage 3 methanol...............
