Diesel Forum - TheDieselStop.com - View Single Post - burnt uvch and vc gaskets
Old 11-15-2009, 11:30 PM   #5 (permalink)
Gone Fishen
If the beast will not start then it could be either the glow-plugs or the gp switch. The plugs were on sale 2 years ago so I just replaced them. I found 3 burn't pins so I made a new harness just for the LS glow plug circuit. I had both under rocker cover harness burn on me so I replaced both harnesses under both sides and both cover gaskets. All 3 years ago. I was at 8700 ft and it was 16*F thursday and it started w/o the plug and I just waited 1 time for the wts light. Fired up on about 6 then the other 2 kicked in. In other words, if in doubt and you need it to start, replace the gp's.
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 189k mi.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
Gone Fishen is offline   Reply With Quote
