Diesel Forum - TheDieselStop.com - View Single Post - Coolant Flow in degas bottle after Coolant filter install
Old 11-16-2009, 08:40 AM   #6 (permalink)
ridintall
ridintall's Avatar
Originally Posted by MikeL46 View Post
How do you see the coolant returning from the filter? Maybe because I have a van, but the reservoir is nearly opaque.
I would assume the coolant hits the tee fitting and goes into the radiator to replace what was pulled from the heater connection. Is there some reason why it wouldn't?
Mike
Hey MikeL46, glad to see you got that coolant filter installed...a PIA it is for sure. Our res. bottles are different than the pickups and appear to be multi-chambered so you can't look inside with the cap off and see any coolant flow back in. On one occasion, I was able to see coolant flow back into the bottle b/c I could just barely see it running down the inside of the bottle by looking from the outside. I would just grab the return line hose and make sure it's hot.
BTW, I've changed out my first filter (after about 700 miles) and poured what I could from the old filter into a clear plastic bottle. There was a bunch of "stuff" (looks like sand) that settled at the bottom of the bottle. I'm going to cut open the filter at some point.
Good job dude.
Oogs
2004 6.0 E350 Quigley 4x4 w/ Sportsmobile Conversion.
285/75R16 BFG AT/KO. 3.73 Gears.
Dieselsite Coolant Filter.
Aluminess Front/Rear Bumpers.
125W Solar Panel.
Sportsmobile Trailer on 285/75R16 BFG AT/KO tires w/ dual deep cycle marine batteries, water pump, 10 gal water storage, air compressor, storage box & 15W Solar Panel.
Wiring Harness Recall - 15K miles
EGR Valve replaced @ 30K miles
Oil & EGR Coolers replaced @ 62K miles
Tank delamination - Reconditioned by Gas Tank Renu @ 62K miles
Vacuum Pump replaced 69K
SnowMan Mod / Door Seal Mod
ridintall is offline   Reply With Quote
