Diesel Forum - TheDieselStop.com - View Single Post - Dieselsite Coolant filter installed - 6.0 Van
Old 11-16-2009, 08:47 AM   #13 (permalink)
ridintall
ridintall's Avatar
Originally Posted by MikeL46 View Post
I finished the coolant filter installation today!.
Mike
Awesome!
Keep an eye on coolant level, I've had to top off after every trip since my install, but I can't see to find a leak. But, I purposely drained a bunch of coolant from the heater core during my install thinking the T-fitting would make a better seal with a dry hose. I found out later that wasn't such a good idea. I'm hoping that I'm just topping off what I drained out. Once I've added more than a gallon I'll do a more exhaustive search for leaks.
Oogs
2004 6.0 E350 Quigley 4x4 w/ Sportsmobile Conversion.
285/75R16 BFG AT/KO. 3.73 Gears.
Dieselsite Coolant Filter.
Aluminess Front/Rear Bumpers.
125W Solar Panel.
Sportsmobile Trailer on 285/75R16 BFG AT/KO tires w/ dual deep cycle marine batteries, water pump, 10 gal water storage, air compressor, storage box & 15W Solar Panel.
Wiring Harness Recall - 15K miles
EGR Valve replaced @ 30K miles
Oil & EGR Coolers replaced @ 62K miles
Tank delamination - Reconditioned by Gas Tank Renu @ 62K miles
Vacuum Pump replaced 69K
SnowMan Mod / Door Seal Mod
ridintall is offline   Reply With Quote
