Diesel Forum - TheDieselStop.com - View Single Post - Air in the fuel
Thread: Air in the fuel
Old 11-16-2009, 03:27 PM   #3 (permalink)
Njellison
Originally Posted by oklahoma diesel View Post
I have a 87 f-250 that keeps getting air in the line. I have riplaiced the mechanical pump and the line to the filter. The truck wont start, i have bled the air out of the fuel system, checked and rechecked the glow plugs replaced the starter, and had the batteries tested, and it still wont start. Can anyone help?
What Justin said for the air and then some. These seperators are notorious for leaking air when under suction but are not the only cause of air leaks. Some others are: poor fuel line connections, leaky injector return caps, poor design of sucking fuel instead of pushing fuel to the IP. Several ways to skin this cat.
Upgrade to a more modern filter/water seperator (similar to mid 90 7.3's) and bypass the old one.
Replace your injector return line caps if they are more than 2 years old with the return cap kit for about $30.
Ditch the old mechanical suction lift pump in exchange for an electric pump mounted pre-selector switch on your frame rail. If you do this one it is nice to have a manual cut-off switch installed just in case.
Have you checked you glow plug relay? I ended up installing a manual button (switch) for my glow plugs and it works like a champ. Some use the newer Relay out of the 7.3 (not sure what year) but I like the positive control of the button.
Work rig - 2000 F250 7.3 4x4 3.73 auto, 285/75 Michelin ATX, hpx, zoodad, hutch mod, 4" mbrp, 6637, isspro 3 pod, Trucool, ATS ported shroud (someday).
Farm rig - 85 6.9 xl t18 4x4 3.73ls, 88k orig miles, zig-style ram air, electric fuel pump, soup bowl delete, manual 12v glow plugs, Battery isolators, KISS principle generously applied.
Njellison is offline   Reply With Quote
