Diesel Forum - TheDieselStop.com - View Single Post - Upfitter switch general knowledge
Old 11-16-2009, 09:06 PM   #15 (permalink)
Willy64
Originally Posted by Sprinks542 View Post
Okay, here's a stupid question. I want to hook up my air compressor for my train horns. I have the switches. I'll look for the wires tomorrow. But where should u hook up to? What happens if your cabs gotta come off? wiring to the inside means a disconnect right? See, to you it was stupid.
Where are you going to mount the compresser?
If outside under the truck bed, just put a connector in line with the wires. That way if the cab needs to come off, you just unplug the connector and lift away. There are connectors at Radio Shack that are called Molex connectors that will do the trick. Be sure to get the high current ones available.
I would use one of the 30 Amp lines from the relay pack controlled by the switches.
Bill in Phoenix
Willy64 is offline   Reply With Quote
