Diesel Forum - TheDieselStop.com - View Single Post - burnt uvch and vc gaskets
Old 11-16-2009, 11:22 PM   #15 (permalink)
Patrick Feeley
Patrick Feeley's Avatar
My Photos: (19)
Oil on the connectors is usually because the connections got very hot and melted the plastic in the gasket around the feed-thru pins. Might as well crank her over with the VCs off so you can look at the injectors and possible oil leakage. Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline   Reply With Quote
