Diesel Forum - TheDieselStop.com - View Single Post - headgasket replacement tips 6.4
Old 11-17-2009, 10:39 AM   #10 (permalink)
Gofaster23
Originally Posted by NORTHRIVER1 View Post
i think you should be fine,i dont know much about the banks chip but i would strongly suggest a pyrometer and run no more than 1400deg at manifold,this guys chip was on 210hp seting and has dpf deleted,i would be more worried about an injector failure as dealers have deen replacing engines for melted pistons from inj.failures
98% of the melted pistons are caused by over full crankcases. At a certain point oil gets sucked into the fresh air inlet tube via the crankcase breather tube, fills up the charge air cooler with oil/fuel, and will work it's way into the intake manifold. Usually takes out the left bank, cylinders 2 and 8 first. It's usually caused by an external fuel leak at the injector fittings or the high pressure fuel pump itself. I've had others where it's just a total lack of maintance and the truck runs 16 hours a day (1 hour equals 25 hours). The truck would have 12,000 miles on it but 880 hours, so thats 22,000 miles without an oil change. The crankcase would get overfull for the excessive idling and have the same effect.
I'm a mod friendly Ford Diesel Technician located in Sacramento California area.
Gofaster23 is offline   Reply With Quote
