Diesel Forum - TheDieselStop.com - View Single Post - hard to start when cold
Old 11-17-2009, 06:43 PM   #7 (permalink)
blageurt
blageurt's Avatar
I assume oil is good ? Have you checked your fuel pressure ? Your lift pump could be going downtown . It should be at least 40-50 psi . Another thing could be the IPR it might be stuck or need a rebuild. Is there any you can monitor the HPOP pressure while cranking like with a scan tool ? If it does not hit 500 psi it will not start.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline   Reply With Quote
