Originally Posted by red.26
ok guys took some parts off my truck. the degas bottle has a brown residue all in the tank. could it be oil?
No, that isn't oil. It's normal and is the gunk that used to be in your coolant passages. Some of that same stuff is likely clogging your oil cooler too and a blocked oil cooler is one of the things that leads to puking.. If you don't have one, when you get your truck properly diagnosed and repaired, add a coolant filter to your truck now to help get rid of the gunk in your cooling system.
and took the intercooler pipe that runs off the turbo and found in the bottom of the pipe right before it goes into the intercooler it has an oil deposit bout the size of a quarter in the bottom??? could it be a bad head gasket?
No, that oil is not from the headgaskets, it is from the crankcase vent system (CCV). You can do the CCV mod (search for it) and stop that from happening but what you are seeing is also normal.
Toreador Red/
Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; AIC; Silverline turbo-back dual exhaust; 155cc injectors from Full Force Diesel (Casserly); SCT with tuning by Tony Wildman (Total Diesel Performance) & Innovative Diesel; ARP studs; Dfuser regulated return; AFE PG7; Fumoto valve; B&W hitch, Di-Pricol gauges; DIESELSITE Coolant filter; Timbrens; Rancho RSXs; Michelin XPS Traction's; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT; JL Audio 275w amp driving a 12" sub; JL Audio 50wx4 amp driving the Alpine door and rear seat speakers. 380.3hp/786.7ft-lbs (on my tow tune!)
pics
#43
SLAPS President and Webmaster
