The ball I think you are talking about is part of the "Non-Serviceable" plug. If you have that leaking you have to pull the pump. If it is the unions on the head or the pump, you should not need to pull the pump.
Here is a guide to help understand the HPOP if you have not seen it. Pretty good info and a few cutaway photos.
7.3L Diesel High Pressure Pump Diagnostics Guide
Ken
Powerstroke Acronyms
TSB Information
