Diesel Forum - TheDieselStop.com - View Single Post - Ignition Switch ACC position?
Old 11-18-2009, 09:47 PM   #7 (permalink)
RWF350
RWF350's Avatar
If it won't turn back to the ACC spot, the tumbler is worn. I took mine out, lightly greased it, and put back. Works much better, still needs a new tumbler though.
In the acc position: radio and windows work, I think the wipers and gauges work as well.
2007 Chevy 2500HD 4WD Ext Cab (late model) 6.0L (gas) 6speed auto
Deceased--1990 F350 2wd DRW Super Cab E4OD 7.3l IDI
Gooseneck hitch, Flowmaster (single inlet/dual out), 60 gal tank/toolbox/bedrails/headache rack (custom built, welded together as 1 unit), 3 gauge pillar pod w/glowshift gauges, oil, water temp, trans temp
Never ask "What else can go wrong?" cause something will.
RWF350 is offline   Reply With Quote
