Originally Posted by geodynamic.tom
'08 f350 SD 6.4L diesel.
I have the same problem, running lights for the trailer not working. The fuse in the CJB under the hood is fine, tested the fuse it's fine, tested for power to the fuse, there is power. Just no power to the harness at the back of the truck.
Is there another place that I can check?
Dont trust your fuse diagram. Its not always completely accurate. Check every fuse in your fuse box and then see if your trailer lights work. I had the same issue a few months ago, and found a fuse that was blown that was in no way associated with the trailer lights, when I replaced the fuse everything worked.
Ryan Kranz
2000 F250 Maroon lariat ext cab, short bed. 2.5" leveling kit, Ranchhand front replacement, custom Headache rack, 285 Revos, Rancho Steering Stabilizer, Tymar, 4" turbo back exhaust (no muffler), Wicked wheel, quad pod with Dipricol optix (boost, pyro, trans, fuel pres), Steering column pod with optix HPOP guage, DI 6 position chip (40, 60, 80, 100, 140, high idle), Fumoto, dieselsite BRV, custom made turn over goose neck hitch, clear corners, silverstars, Cobra 29 CB, CCV, Blue IC Boots, TC lock up switch, LED side marker lights, cab lights with smoked lenses.
Let freedom ring and the turbos sing.
People that have treated me right:
DI, Diesel Power Products, SP Diesel, Dieselsite, ITP
302 HP/720 TQ (In the 80 setting)
If it dont smoke black, take it back
picts
