Diesel Forum - TheDieselStop.com - View Single Post - Need Help Asap
Thread: Need Help Asap
Old 11-19-2009, 02:45 PM   #1 (permalink)
lpfd778
Location: Moberly Missouri (about 30 miles north of columbia)
Need Help Asap
Have a 99 7.3 that is giving intermentant problems with wts light not comming on and check engine light not coming on and no start and then today was driving truck and it died and wouldent refire till after it was towed home and sat for about 3 hours it is throwing a code of P0603 pcm processor keep alive memory (kam) error dont know if that is the problem or not any help would be appriciated this truck is stock with 4in exhaust as the only mod and has 146xxx miles on it
2000 Ford F-250SD balanced 7.3 6speed with Hypermax h2e turbo 530 injectors afe stage 2 air intake, fluid damper, twin 5 in turn out stacks, south bend duel disk clutch, ts 6 position chip, 18k mod, head studs,Built by BWD thanks Brian
2005 Ford f-250SD 6.0 auto with a steroid modual
lpfd778 is offline   Reply With Quote
