Brakes pull to the right a bit
Well, this has got my mechanic stymied.
The truck pulls to the right when the brakes are applied. Not a huge amount, but enough that one cannot let go of the steering wheel. And, its not because of the crown in the road.. I've tested for that on flat surfaces.
My trusty mechanic found a right side caliper that was sticking and replaced that.
The other caliper is fine, the flex lines are good and the left slides are lubricated and working well.
Everything else seems to work well, but it still pulls to the right.
Any ideas what to look at before we start throwing parts at it?
1999 Ford F250 Supercab 2WD Powerstroke, Line - X, Fumoto Oil Drain valve, 6637 air filter system, and more to come..
