Diesel Forum - TheDieselStop.com - View Single Post - want up fitter switch
Old 11-19-2009, 05:34 PM   #3 (permalink)
BTBBT
My Photos: (19)
The cutting and mounting is what most worry about. It's usually the only issue. Wiring them up can be done relatively easily. Go for it!
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline   Reply With Quote
