Diesel Forum - TheDieselStop.com - View Single Post - Ignition Switch ACC position?
Old 11-19-2009, 07:53 PM   #9 (permalink)
StrokerSmoker7.3
StrokerSmoker7.3's Avatar
Is there supposed ti be a little button on the bttom of the steering column that you have to push to rotate it to ACC? There is a little square hole on the bottom side of the column under the IGN. Is this what is supposed to be there?
1989 F-250 4X4 C-6 7.3 IDI, 4.10 SRW, Cobra 148GTL, 4ft bed mounted whips, 12" Powerbass sub, 600W Powerbass amp, Sony Headunit, GPC override(thanks M.L.S.C), Factory Ford aluminum rims from OBS PSD, 4" exhaust, no soupbowl, B&M shift kit
1997 F-350 4X4 E4OD 7.3 Powerstroke, 3.55 SRW. 3"DP to 4" exhaust, TS performance 6pos. chip, Quadzilla Recon XGT, DIY Tymar style intake, Atwood fiberglass cap
StrokerSmoker7.3 is offline   Reply With Quote
