Diesel Forum - TheDieselStop.com - View Single Post - Oil Analysis for my 6.0
Old 11-20-2009, 12:21 AM   #1 (permalink)
Smiley1
Smiley1's Avatar
I used Blackstone Labs for my oil analysis. This was the first UOA for this truck. I am somewhat satisfied with how the truck is doing. The engine has 32,400 miles with 5,200 miles on the oil sample. Unfortunately, I was not able to resize it. If you click on the little bar it will get just big enough to read.
Here are the comments:
ROB: You were interested in fuel dilution and engine wear. No fuel was found in the first sample from your Ford. All
wear metals, except lead from bearings, read right around the universal averages for the 6.0L PSD. Lead at 9 ppm
either is a sign of some extra bearing wear or it's due to a particle streak through one of them. We'll know more after
we see your next sample. Oil viscosity was normal. No moisture or coolant was present in the sample. Air and oil
filtration (see silicon & insolubles) were normal. Other than lead, everything looks great. Check back to monitor.
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs / Coolant Filter / CCV
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
Smiley1 is offline   Reply With Quote
