Diesel Forum - TheDieselStop.com - View Single Post - Oil Leak!!!
Thread: Oil Leak!!!
Old 11-20-2009, 11:26 AM   #14 (permalink)
Rickie
Rickie's Avatar
Originally Posted by woodnthings8 View Post
The ball I think you are talking about is part of the "Non-Serviceable" plug. If you have that leaking you have to pull the pump. If it is the unions on the head or the pump, you should not need to pull the pump.
Here is a guide to help understand the HPOP if you have not seen it. Pretty good info and a few cutaway photos.
7.3L Diesel High Pressure Pump Diagnostics Guide
If you have a leak from the "Non-serviceable" it can be fixed, but only after removing the HPOP? That doesn't mean you have to replace the pump, right? Can a novice remove the pump and remove the plug, or does it take special tools to service the "non-serviceable" plug?
'00 F250 XLT 4x4 (born on 6/00), manual tranny & hubs, SPA Techniques EGT/Boost Gauge, Homemade HX Crossover Mod & Return Fuel Regulator, Toro Liner, 203* T-stat and Coolant Filter, LUK Clutch, flywheel & pressure plate, Amsoil Dual Bypass Filter
Rickie is offline   Reply With Quote
