Diesel Forum - TheDieselStop.com - View Single Post - want up fitter switch
Old 11-20-2009, 03:25 PM   #4 (permalink)
greasemonkeyf350
There is a member on here that put them in the map pocket and just had to make a little filler panel to take up what the switches didn't cover.As for wiring there is one main power wire that plugs into the fuse box so that is all you have to deal with.You could tap into the ignition switch harness with a fusible link if you had to.
2000 F350 srw pickup
3 in. leveling kit,35x12.5x16.5 BFG's,K&N air filter,4 in. exhaust from turbo back,Bully Dog boost,trans temp and exhaust temp gauges,Painless wiring inline module,Western Diesel four position chip(currently out being repaired),203 thermostat,Bully Dog shift kit.
greasemonkeyf350 is offline   Reply With Quote
