Hi-Idle Mod
A buddy of mine has a very similar truck to my own, minus the mods, his is stock except for the DIY Tymar, and he wants to wire in a Hi-Idle switch. I have a 6 position chip with the Hi-Idle mode built in. My brother wired a switch into his 6.0 to get Hi-idle and I had assumed we could do the same with the 7.3. all he had to do was find the wires under the dash and hook up a switch. I searched the forums and found the mod including a couple potentiometers and some fairly intricate wiring. Is this (and the stealerships factory Hi-idle box) our only option. I figured it would be simpler.
03" F-350, 7.3, Lariat CC SRW 4x4 SB
-Bully dog 6, BTS trans w/ 6.0 cooler, 175 cc single-shots from Swamp's Diesel, 4" turbo-back, AFE Stage Two w/ Pro 7, Autometer pillar gauges, DB starter, foil delete, 3" Tuff Country level kit, on board air, truck horns, bellowed up pipes, big ball in the bed.
!!BTS BUBBA!!
