Diesel Forum - TheDieselStop.com - View Single Post - Transfer Case Over-Full???
Old 11-22-2009, 02:07 AM   #6 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Originally Posted by Notch1320 View Post
What is involved in replacing the rear tranny seal?
Sorry, don't know about that. I couldn't see a seal in the blowup on the 4x4 extension housing. Your tranny shop should be able to tell you about that.
Is there a seal on the input side of the TC as well?
Yes, there's an input seal on the t-case input shaft. Should just be a pry-out and drive in a replacement unless something else is worn.
A PM to Mark Kovalsky here on TDS would help you. He's VERY familiar with these trannies (former Ford tranny engineer).
Hard or no-start? Check Here
