Originally Posted by StrokerSmoker7.3
So I should just be able to rotate CCW to ACC? No buttons need to be pressed or anything? Sounds like my IGN. tumbler needs a replacin...
Your ign tumbler only rotates. The end of it has two "ears" that fit into a slot to move electrical contacts. If your not having a problem turning the key then the tumbler assembly is good.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
