Mine has a spring loaded ball in the tumbler that stops it at a detent for "off". It had worn a groove in the "outer" tumbler case that the ball could not over come to go into acc position. I took the tumbler out and I put a light dab of silicone grease in the tumbler where the ball is at with a q-tip. Works pretty good right now.
2007 Chevy 2500HD 4WD Ext Cab (late model) 6.0L (gas) 6speed auto
Deceased--1990 F350 2wd DRW Super Cab E4OD 7.3l IDI
Gooseneck hitch, Flowmaster (single inlet/dual out), 60 gal tank/toolbox/bedrails/headache rack (custom built, welded together as 1 unit), 3 gauge pillar pod w/glowshift gauges, oil, water temp, trans temp
 Never ask "What else can go wrong?" cause something will.
