Originally Posted by firedog533
mile maker has sevral on the market that is ran from the power stearing pump it will pull the full load at idle and you can get a remote to go with them i have used one many times on fire runs and you cant beat them with a stick.
what good is a elc.wench if you are stuck you get unstuck and now have a dead batt. This is a very powerfull set up and it only takes about half of the space to mount it. the install kit has all the fittings and hoses to make a very prof. install.
just my two cents worth.
I am pretty sure that is why it's mentioned above to leave the engine idling when using an electric winch.
Evan-
2003 Ford F-350 Crew Cab L/B/Dually XLT FX4 7.3L/Auto- Gooseneck Hitch Fifth Wheel Rails, Firestone Air Bags/ Toolbox
