I live just a few minutes fro Pensacola Diesel, there local reputation is second to none. I have done limited business with them and have been happy thus far.
racer-X
I reved the motor a few times to that before I loaded the turbo just in case any more metal shavings were in the manifold from the pyro install. Unloaded the turbo does not spool near as much therefore less likelyhood of meatl damage just in case. Also a miss is a miss loaded or unloaded. I depend on my truck to make my living aand if it goes down 1 day I loose more money than if I go ahead and find the problem and fix it. Prevenative Maintanence.
Speedrcr78, Thanks it is at Pensacola Fuel Injection now getting scanned. I have read several tech articles on replacing injectors and you have to take a lot of parts off the top of the motor just to make life easier on yourself to change the injectors. Since it is started this is the time to install it. I also have to install manifold gaskets because mine have started leaking some. If there are any other ideas where I can get good reman injectors for around this price that info would be greatly appreciated.
2003 F350 FX4 4" Magnaflow turboback no cat. SCT X3 Spartan tunes Autometer guages
2000 Excursion 4x4 4" Exhaust, Guages, Volant Cold Air Intake, wicked wheel (not installed yet) trying to get a chip or programmer to work.
