I don't know if this will help, but I had a 01 f250 that I had the brakes done on at a local brake shop, after brakes were done, truck would pull to the right slightly. Took it back to shop and they said it was an alignment problem, brakes checked out okay. Took it to an alignment shop, and they said everything was right on the money. Truck still pulled to the right. I took it back to the brake shop, & raised alittle stink. They pulled the tire again and looked at the right front caliper. Shop foreman noticed that the brake line was twisted from previous tech installing the caliper with the brake line twisted. That twist was enough to keep some pressure in the hose, causing caliper to stay slightly engaged. They took the caliper off, spun it around reinstalled it and that solved the problem.
