Originally Posted by teesh
Firemedic.............How much were you able to remove from the pump?
I was only able to remove about 3/4's of a quart.
Like you, I was able to remove a little bit better than a pint at a time. I did this over and over again, refilling and letting the truck run in between, until I had removed 3 quarts. Even after I had two fresh quarts in, when I removed the third quart it was blacker than I would like to have seen, but better than I had started with.
Interesting to read the different opinions, but good discussion regardless
1999 7.3 F-350 and 2004 6.0 Excursion
Truck: Tymar type intake, Zoo Dad, muffler delete, By-pass coolant filter, Dahl 100 fuel filter Harpoon & Hutch mod, upgrade to 3/8" fuel line and HP oil X-over, Oil by-pass, Scan gauge II.
Excursion: All stock, so far.
