Originally Posted by firemediceric
Interesting to read the different opinions, but good discussion regardless
This... "Obviously this black oil had not mixed with the new honey colored oil."...is an opinion.
This... "It isn't possible for it to "not mix". The oil supplied to your injectors comes from the HPOP reservoir. The injectors use 7 times as much oil as fuel. The injectors dump their oil into the crankcase. The HPOP reservoir is replentished from the oil pan. You will use about 15 gallons of fuel in 250 miles. That means there has been 105 gallons of oil pumped thru the injectors."... is not an opinion.
