Diesel Forum - TheDieselStop.com - View Single Post - Brakes pull to the right a bit
Old 11-27-2009, 03:09 PM   #12 (permalink)
FMTRVT
FMTRVT's Avatar
My Photos: (16)
Originally Posted by Greg03PSD View Post
Just a shot in the dark here, but have you tried bleeding the brakes (specifically the left front caliper)? Some air trapped in that caliper might prevent building pressure on the left side due to the air compressing. If the right caliper does not have air, it would build pressure immediately. The difference in pressures (higher on the right) could cause a pull to the right.
Common belief, but not exactly right. With air on one side of an axle's brakes it causes a slight delay in apply on the side with air, but the air will compress to the applied pressure and brake torque will even out. You typically feel a quick tug on the steering wheel towards the non-air side and then it goes away.
Air will require more fluid volume to that one side, but neither the pedal or master cylinder cares about that, they will just travel farther for more displacement. But if the applied pressure at the master is 500 psi, the air bubble then compresses to 500 psi, and the fluid downside develops 500 psi.
Jack
Truck Modifications below in Pictorials on Facebook. Search in Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline   Reply With Quote
