My 2004 with 65,000 miles has some bad fumes in the cab, I thought it was just the wind. Sitting in traffic with vent/defroster on is the worst, once moving, no problems. After researching this site and crawling under truck seems the Y-Pipe is leaking. I am a fair mechanic and do a lot myself, but this looks like a PITA. How much would a dealer charge, and how good would the replacement pipe be? Can any exhaust shop do this? I've seen some aftermarket y-pipes on line. Also, would this leak explain a power lag on take off? No other issues, the truck runs fine and is all stock except for muffler delete.
So many questions, I've only had this 6.0 a few months and I want to like it.
Thanks for any help................................hparm
Got the same type smell in my cab as well. I have not checked my Y pipe yet but will now. My dealer could not find the cause of the smell two weeks ago. Anybodys input would be helpful.
Same thing here - turned out to be loose clamp on turbo exhaust and loose exhaust manifold bolts - mostly gone now - but there's still some remnant - so I will have to check it further.
It's not that big of a job. The worst part is getting the front of the truck jacked up high enough off the ground to get the downpipe out.....if it's the factory one. Remove the trans x-member, and jack up the trans and truck about 2 feet high. The downpipe will snake out. Take your time, it will come out. Loosen the y-pipe from the turbo and both sides. Slide it over to the right side, and it will come down behind the engine and out the bottom where the downpipe did. :thumbsup::thumbsup::thumbsup:
I just had a cracked Y-pipe repaired two weeks ago. About $700 to repair at the Ford Dealership. And, yes, this problem will not only cause fumes in the cab but also lack of power/boost at takeoff.
I did some research ($750-$875) and decided to have it replaced at a local Ford dealer who helped me out on the price ($700 parts, labor, tax) The tech has done many of these and after I fiqured the cost of parts the cold weather and a chance of screwing it up, I let him have it. My wife has too many things for me to finish on our home at the moment and I didn't want to hear the b**ching about laying under my truck for hours.
If anyone decides to fix one themselves, give us a call. I can help you out a bit on parts. We sell quite a few of these; I usually have them on the shelf.
Does anyone have any good tips on removing the y pipe from a 06 250. It's cracked on the right side and I have more time than money so I m taking it on my self. Any help is good help thanks for everything.
If you take the turbo out, it's not to hard to get the Y pipe out.
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
